Vieux 24/04/2019, 09h48   #1
Par défaut Re : Batterie de portable
Ici y en a un qui avait le même problème voici sa solution:
My laptop is ASUS UX410UAK with Win 10.
For me it worked following these steps:
1. Download the ZIP from the link provided by Brian.
2. Install the ASUS Battery Health Charging app. (The options are grayed.)
3. Edit the registry following Viserion's advice from another question, namely:
1. With regedit go to HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\ASUS\ASUS Battery Health Charging
2. Modify the CheckSupported value from 1 to 0
3. Reboot your system
Vieux 24/04/2019, 14h13   #2
Rocket
Merci beaucoup simple comme bonjour, Tout fonctionne
Bonne soirée
Fuseau horaire GMT -5. Il est actuellement 00h34.
